RG-PF2920U-4GT1MS-P
Compact Size Compact Size
Fanless Design Fanless Design
Find out details >>
Model (Non-PoE)
RG-PF2920-8GT2MG2XS
RG-PF2920-16GT2XS
8 x 10M/100M/1000M auto-negotiation electrical ports
2 x GE/2.5GE auto-negotiation electrical ports
2 x 10GE SFP/SFP+ ports
16 x 10M/100M/1000M auto-negotiation electrical ports
72 Gbps
49.1 Mpps
53 Mpps
SFP+ port
10GBase-R and 1000Base-X supported
2 x PoE inputs (802.3at): PoE-IN1 and PoE-IN2
Rated voltage range: 44 V to 57 V
Rated current: 0.5 A
Leakage current to ground
≤ 3.5 mA
EEE energy saving
PoE output
Max. power consumption
< 20 W
Installed on a wall or cable tray or in a rack: 0ºC to 55ºC (32ºF to 131ºF) at a height below 1,800 m (1.12 miles) above the sea level
10% to 90% RH
5% to 95% RH
GB/T 9254.1-2021
Safety standard
GB 4943.1-2022
Dimension (W x D x H)
2.75 kg (6.06 lbs, including the package)
Model (PoE)
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
1 x 1000M/2.5G SFP port
1 x GE SFP port
9.7 Mpps
SFP port
Rated current: 1.3 A
Rated current: 0.75 A
≤ 3.5 mA
EEE
1 x downlink POE/POE+ port
Overall power consumption
Without PoE load: ≤ 15 W
With PoE full load: ≤ 75 W
Without PoE load: ≤ 3 W
Overall power (PoE+) ≤ 33 W
10% to 90% RH
10% to 90% RH
5% to 90% RH
5% to 95% RH
GB/T9254.1
GB/T9254.1
Safety standard
GB 4943.1
GB 4943.1
Model (Non-PoE)
RG-PF2920-8GT2MG2XS
RG-PF2920-16GT2XS
Max. number of MAC address entries
Static MAC addresses
4K IEEE 802.1Q VLANs
MAC-based VLAN
Protocol-based VLAN
GVRP VLAN
Port aggregation
VSU aggregated port
One-to-one mirroring, one-to-many mirroring, and many-to-one mirroring
DHCP Snooping
Static black hole routing, RIP, OSPF, and RIPng
Standard IP ACL (IP-based hardware ACL)
Extended IP ACL (hardware ACL based on the IP address or TCP/UDP port ID)
Global ACL
IEEE 802.1p/DSCP traffic classification
Queue scheduling mechanisms such as SP, WRR, DRR, WFQ, SP+WFQ, SP+WRR, and SP+DRR
SSH and SSH V2.0
EEE
EEE LPI mode on ports of the IEEE802.3az standard
SNMP, Telnet, Web, RMON, FTP, TFTP, NTP/SNTP, RLDP, and Syslog/Debug
Model (PoE)
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
Password protection
EEE
APD port sleeping
IoT MQTT
Syslog/Debug and SNTP
RG-PF2920-8GT2MG2XS
The 8-port non-PoE switch provides 2 x 10GE uplink optical ports, 8 x 10M/100M/1000M downlink auto-negotiation electrical ports, and 2 x GE/2.5GE auto-negotiation ports, and supports power supply over the hybrid cable (10GE SFP+ port and PoE power supply input. A wide operating temperature range of 0°C to 55°C (32°F to 131°F) is supported, and an optical link fault LED is provided.
RG-PF2920-16GT2XS
The 16-port non-PoE switch provides 2 x 10GE uplink optical ports, and 16 x 10M/100M/1000M auto-negotiation electrical ports, and supports power supply over the hybrid cable (10GE SFP+ port and PoE power supply input). A wide operating temperature range of 0°C to 55°C (32°F to 131°F) is supported, and an optical link fault LED is provided.
RG-PF2920U-4GT1MS-P
RG-PF2920-DPBOX-P
404
Sorry, we can’t find this page
Let’s find what you need
Products
Solutions
Partner
Go to our homepage
